Lanesville, IN
I have a 2020 yz450f. Has 17 hours on it, I bought it used at 13-14. Bike ran flawlessly the 2 times I took it to the track. The 3rd time I got 3 or 4 minutes in, landed off a jump, the bike coughed, sputtered, and died. I tried to start it for a few minutes, but it would crank, backfire, and wouldn't start. After I let it sit for 10 minutes or so it would start, idle absolutely perfectly, but as soon as I added any throttle it would die. I got it home, changed the battery out, it started and ran absolutely perfectly for about 2-3 minutes, revving it up and all. Then it went back to shit, except it would not even crank, it was totally dead... I had a friend/diesel mechanic look it over, we found a blown fuse. When replaced it started to turn over again, but it refuses to start. It's getting spark, all the wiring tested good, it has fuel, fuel pump is at least kicking on, etc.
Before I take it to a dealer and get molested, any ideas???
May not be helpful, but it’s a known electrical mistake for this bike and worth a look. Best of luck.
A connection is bad and the power or grounding requirement from the circuit is not met by the physical connections.
A short has occurred.
Or a component has drawn more current than it safely should have, like a failing fuel pump for example, making it harder for it to work and the current raising as a result.
9 times out of 10 an even slightly iffy connection, most often grounds, can cause all sorts of intermittent or seemingly unrelated things to play up, so the above advice is well worthwhile as is the chafing / rubbing through wiring if routed incorrectly. Hope you get it sorted with a dealer-bumming.
Post a reply to: 2020 yz450f electrical issues???
