Annapolis, MD
All,
I have about 20 hours on my bone stock 2020 KTM 250SX-F and I am having an issue with possible flame outs? Not sure if I am on the right track or wording this correctly, but I have had a few occurrences where I go into the first turn or have to brake hard going into a turn and the bike will shut off. Clutch is pulled in and seems to still have good life. It has happened on the line as well when I shift into gear it will occasionally shut off and can be difficult to start. I have tried 93 Octane, Sunoco CAM2, VP110, T4, and T4/93 mix with basically the same results. Is this something that I should look into mapping my bike differently? Should I change fuels? Looking for some guidance.
Another thing I have noticed is when the bike is first fired up. There is a noticeable tick for a few seconds when the bike first fires up then it goes away. Not sure if this is a common issue but it is slightly concerning.
Thanks in advance.
Thanks in advance.
cam chain tensioner takes a second to load up with oil pressure
works best w slip on or full exhaust
easy to install
Post a reply to: 2020 KTM 250SX-F Flame Outs? Other possible issue noticed
