Lanai City, HI
4/5/2019 9:17pm
Hi, new to this forum,
I just started riding and im wondering whats the best fit for my ride!
My height is 5’3, weight 145lbs, I barely cant touch the ground so i drop the rear shock so i can touch the ground,, i want to make it a great feel andwhat should i do to adjust the front and rear .. any suggestions would be very helpful..
If you just lower the rear, the bike won't handle properly, especially in the corners.
You can check into various years of YZ250F and YZ450F foot pegs.
I run the 2010 YZ250F foot pegs on my YZ125 and YZ250, because they're more durable and wider.
Some of those foot pegs from the late model 450F (2010 and later) are a bit higher (about 4mm or 5mm) which may suit you better. Do a little research around the forum, and on the web and you'll find the info on which pegs are which height.
I run the pegs from a 2010 YZ250F on all my two-stroke YZ's because they're much wider and more durable, but the same height as stock two-stroke pegs.
Post a reply to: 2019 yz125
