Lincoln, CA
7/2/2019 7:14am
We are having issues with the rear brakes locking up. First ride on the bike went through a set of pads, pads were bent. Took it to the dealer, they replaced rear caliper. Seemed to be fine then after a couple practices locked up again. Destroyed rotor and brake pads. Replaced rotor and pads. Today during the second moto last lap rear brake locked up. Could hardly spin the back wheel. I'm lost and frustrated. Any ideas
Also does anyone know where I can get an aftermarket replacement for the 2019?
Do people generally ride with their feet lilghtly resting on the brake pedal? I have a habit of doing that and that bit of friction completely fries my back brake on the 2019 kx 450. Other bikes seem to have more play before the back brake rubs.
My rotor was also cracked over the weekend. I bought a crappy one from the track shop and that got so hot the metal started to de-laminate. The caliper gets hot and the prongs that press the pads start to bend.
I have added braided lines and gone to the smaller brake rotor.
Also I am using either DP or oem pads.
Additionally I have lowered the pedal by grinding part of the screw at the bottom of the master cylinder.
Anyone found a solution to this yet except for riding with their feet up off the brake pedal which i find quite hard!
I have been thinking to get a stronger return spring. Do you have a link to the spring please? Ill get one ordered.
Thanks,
Post a reply to: 2019 kx450 rear brakes
