GRAPEVINE, TX
Ok guys suggestions please. Bought a 2019 kx 450 used and pulled the motor out to inspect the cases. Did not tear into engine and cleaned up motor and put it back in frame. Replaced battery and had starter checked out to make sure it was good. Got it all back together it will try to start for a second and die. Has spark but either not getting enough fuel or bad sensor maybe ? Also it drained new battery by turning it over maybe 20 times. Any suggestions before I take it to shop to be checked on the laptop.
Compression - 60psi+
Spark - have
Pass leakdown test
Fuel - if its got fuel it should pop every once in a while
Clean filter
Fresh gas
& check tip over sensor and all connectors including kill switch.
Being my first EFI I was not aware of how this sensor acted..took me a week to finally figure it out
Would start and if I kept the RPM's above say 3500 it would run and I could ride it as soon as I let it drop it would die..
turned out I had the Tip Over sensor installed upside down!!!!
Here is the video I posted on YT showing how it reacted with the sensor upside down
https://www.youtube.com/watch?v=1YfTUqwdJds
https://www.youtube.com/watch?v=Ooaza1x_vjg
disconnect and reconnect
Post a reply to: 2019 kx 450 will not start.
