2019 YZ250F CLUTCH PROBLEMS
10/29/2018 3:43 PM
Has anyone else had clutch problems on their 19 YZ250F? Done 2 clutches in 30 hours on mine. Not abusing it either..
10/29/2018 4:27 PM
Using incorrect oil?
10/29/2018 4:50 PM
Stay away from most synthetic oils. The only 2 synthetic oils that have not affected my clutch performance are Motul 300v and Rock Oil.
10/29/2018 5:22 PM
Using fully synthetic 10-40w which have also used on KXF 250 and 14-18 YZ250F with no problems.
Perhaps I should look into semi synthetic oil instead?
10/29/2018 7:39 PM
Is the oil rated for wet clutches?
10/29/2018 8:56 PM
No, if it ain’t broke, don’t fix it. On the ‘18 yz450f and 2019 yz250f I have, it was a really noticeable slipping on the synthetics I was asked to try.
Back to the OP’s question, no I haven’t had the same issue, neither has Keefer. So he says, when he tested the yz250f and he said he is known to use the clutch a lot.
I would go to his site and ask him the question, he will answer.
