2499th
pdub187
6/27/2020 6:01pm
6/27/2020 6:01pm
I'm having trouble finding an extended shift lever for my RMZ. I have a size 14 and have always run the hammerhead +20. I see that they only offer a lever for the 450. Will this fit the 250 or does anyone know of any other options? Thankyou.
I thought I would give it a try and see if I could make it work. I used the spring from the Tusk shift lever. I had to bend the end of the spring but it works fine. I would guess you could get a tusk from Rocky Mountain for your RMZ and use the Hammerhead plus tip. I bet the ends of the Tusk Shift Levers are all the same. Worst case you send it back.
Post a reply to: 2019 RMZ250 extended shift lever
