Williamstown, MA
rob27ma
1/4/2020 8:14am
1/4/2020 8:14am
Getting ready to put a new OEM top end into my 2019 KTM 250 SX and received a vertex gasket kit with 4 gaskets. Unfortunately I already removed the original gasket that came in the bike and threw is away a couple weeks ago so I'm unable to measure the original one to see which should be used. Does anyone know what gasket(s) size is used direct from KTM on this bike?
Also, if I increase the gasket size, how would that impact power? More low end or top end?
Put the middle of the road gasket on with no ring on the piston. Use a dab of grease and lay the solder along the wrist pin location on top of the piston. Throw the head on and kick at least 2 rotations. Pull the head and measure the "squish" . The flat spots on the ends of the solder. Take the caliper and measure the flat spots. You really want to be in the .028 to .032 squish. I raced TZ250s for 15yrs and the squish never set above .030
I also had the luxury of 3 different head cc configurations. I dont want confuse with all the head cc stuff.
Go with the. 030 and you'll be fine.
I +1 the comment about measuring the squish to make sure youโre in the correct range. Itโs very easy and tons of videos on YouTube to help.
I was hoping someone would know which of the gaskets came stock on this year bike so I could just use the same exact one. So far I have seen conflicting feedback as to what size comes on KTMs, other than .5 or larger seems safe.
Moisture-wicking fabric provides a soft, lightweight fit
OP, for my modified engine I was running 1.2 mm of squish. keep in mind though I'm running T2 fuel (105 octane).
I sent my TZ250 cyl out and tried to them to the porting specs I was given. Nothing made sense as the readings came out all F$#%d up
I then realized I was using the larger diameter solder. .
Use the 32 thou solder and your reading nightmares are gone.
Which is why they include several gaskets with various thicknesses in the OEM piston kits, and advice you to measure the "X-distance" and add/remove gaskets to get it right.
Post a reply to: 2019 KTM 250 SX Base Gasket Need Help, What Size?
