Goleta, CA
8/20/2021 8:17am
Does anyone with a service manual have the torque spec for the front sprocket nut for the 19, 20 or 21 kx 450? Don’t want to guess. Any help is much appreciated!
80 Nm
I have checked everything there is to check (fuses, pump, battery, connections) and still not getting power to the connection to the fuel pump. There is mention of a relay but I cannot locate it in the manual nor on the bike... Anyone have any ideas?
Battery is good, replaced fuel pump, relays, checked voltage at every point, etc...suspect broken wire in wiring harnesses..
Post a reply to: 2019-2021 kx 450 torque specs.
