1941st
Jetting seems to be really good right off of the showroom floor. Added a FMF factory fatty and powercore silencer and it still runs great. MXA recommended to go up to the 440 main jet from the 430 that comes stock.
My next investment is going to be the vforce reed cage setup. This would make sense to go up a size in the main jet correct? More air would mean needing more fuel. Just hoping i have this correct.
Any advice appreciated, thanks
OP, you won't get any more power, but the initial throttle response and snap was noticeably better for me, anyway.
You will not need a bigger main jet nor needle adjustment, but you may need a bigger pilot or at least go out with your air screw.
If you are looking for more power, however, then I'd suggest going another route initially. The bikes I had reeds on were ported and had head mods. I added the reeds later and was happy.
Post a reply to: 2018 yz125 jetting help
