2018 ktm linkage
6/28/2018 6:32 PM
i am trying to grease my linkage, is there any way to get the seals out? or am i kinda screwed.
6/28/2018 6:37 PM
Edited Date/Time: 6/28/2018 6:37 PM
Why would you be screwed? Just gently pry and they pop out. You would be screwed if you waited a year or 3 and had rust.
6/29/2018 5:47 AM
The Kim"s have a metal band around the seals, have to be careful when removing or they can get deformed. When I greased mine a few of the needles came out & got lodged between the bearing cage & seal, had to remove seal to get them, damaged seal, had to order new seal...the little needles can be a pita if they come out during greasing.
6/29/2018 6:14 AM
I don't remember any issues like that with mine,(17) pretty quick job. Definitely have to mind what you are doing however.
6/29/2018 9:35 PM
You don’t need to take any seals out if you just want to clean and grease. Pretty easy job. Lube the bearings in the knockle of the linkage as well.
