Charlotte, NC
2150th
4/16/2022 12:38pm
Wanted to do the top end on this YZ I've had for a bit, grew up putting around on 4 strokes and never did any engine work myself. Saw that you need to order a piston that corresponds with the type of cylinder, and when I checked above the intake, I didn't see a letter to denote the size of the cylinder...
Any idea what this means? Am I looking in the wrong spot for this? Googled "yz250 cylinder no letter" and that wasn't much help.
Not an expert, but I have had a few yz’s and I’ve yet to see anything stamped besides “B”. That also being said, I would run a “D” piston whenever I did a top end and never had any issues. I know there are a few other yz connoisseurs on here including Mr. Robinson, mwilcox349, and cdoggy81 that I bet could provide some more info.
I personally would use an aftermarket forged piston.
If you can see crosshatching & no score Lines or plating flaking off then your cylinder will be fine.
The differences between cylinder sizes A-D is like .01” per letter size. Basically on a cast piston & their expansion rate you would be good with any size slug in that hole.
Here's the actual sizes for each letter piston.
Your link above doesn’t work but here is a pic from my collection of yz notes:
Anyhoo.....i have a new "B" piston for sale for the 2014 YZ250 if anyone needs it.
Thanks to each of you for the help!
Post a reply to: 2018 YZ250 - No letter on cylinder?
