- Pick trends
- Create a private league
- And more!
I think it depends on the style of track and dirt you ride. Because i've heard of people running almost every combination.
Gear Ratios-
14/50 = 96.4
13/48 = 99.97
14/52 = 100
13/50 = 104
13/51 = 106
To give you context of what the ratios mean, for example if you tried each of those while in 2nd gear of the bike. The lower number will be less snappy but pull farther and higher top speed. The highest number will be more snappy but wind out faster on the top end. The key is to find the best of both worlds for you, your bike and riding style.
Are you sure your 2016 SX 150 came with 13/50 ? I was sure stock was 13/48.
I’ve tried 49,50,51. Currently sticking with 51 for the tracks I ride.
If you can try and keep your rear wheel in the middle to back of the swingarm slot. It will help with stability on fast sections.
Post a reply to: 2018 KTM SX 150 gearing
