Anderson, SC
4/2/2018 12:23pm
Having an issue the bike bogging, but happens after about 2-3 laps. No bog before that and runs amazingly. Almost like a vapor lock type of bog. Continues sitting on the side of the track.
Already checked the gas cap and put a brand new plug. No change. Any other suggestions?
Also check your carb vent lines.
Thx for the feedback.
pulled the bike apart and found connecting rod bearings were toast....
I rebuilt the bike and the issue came back... bogged down on me one time and the lower end felt hot... put it back in the garage and noticed the fuel line had no fuel. Opened the fuel cap and suddenly fuel filled the line.
I pulled the line and put it into a gas can and found that it would only pour fuel for about 4 seconds before it would stop. open the gas cap and fuel started to flow again then put the gas cap back on and it stopped...
root cause was vapor lock due to the gas cap not venting...
becareful letting it continue to bog... its about 800 bucks to replace the lower end with parts only...
Just thought I would share to help someone else out. I've never seen this happen before where the root cause was the gas cap...
Post a reply to: 2018 KTM 85SX bogging
