Ford City, PA
Went to change the oil on my bike and I could not get the bolt for the oil screen by the shifter. I ended up rounding it off. What can I do? I'm literally so pissed off at this bike. I swear the bolts are made out of plastic. I called dealership and they don't even want to mess with it.
For your problem i would definitely tey and get a deep impact on there the next socket size down, hammer it on good and go from there. If that fails try and weld something to the bolt that would give you leverage to remove the bolt
Also, dont let it hold you back from riding. The magnetic bolt is the more important one as its lower and catches the filings so if needs be get her drained, filled and take her a rip! Good luck mate
https://m.sears.com/craftsman-10-pc-damaged-bolt-nut-remover-set-low/p-…
It’s not a big deal to take those out either way even if you can get it off. I only clean mine ever 2-3 oil changes.
Post a reply to: 2018 250sxf oil screen bolt stripped.
