Vancouver
Just doing some maintenance on my bike, took it all apart for regreasing, etc. Put the forks back on nice and even then when I go to put my front wheel back on the axle doesn't want to slide though easily because one of the forks is sitting higher then the other one for some reason. The fork tubes are perfectly even in the triple clamps but one of the fork legs is higher then the other one and I can even pull on it and see it come down a few mil but it goes back up when it's released. Anyone know what might be going on here?
Remove the 10mm bleed screw. If a lot of air escapes you'll need to rebuild the inner chamber with new seals.
Post a reply to: 2017 sxf450 front axle/fork issue
