- Pick trends
- Create a private league
- And more!
local moto shop and have them charge it for you. Most places will do it, no problem, for a small fee.
The air we breath is 78% nitrogen. It will work fine and its free.
Also I can tell you my 1982 RM 80 called for Nitrogen so when did Suzuki call for air?
What I do is when I bring the shock in to the shop to have charged, I have it
pressurized from the air compressor at home. That way they are assured that the clips are in securely.
All good shops should have the needle required for your KX shock. But I would swap it out for a shrader valve style cap like found on other bikes because I’ve had that rubber bullet that the needle pierces inside the cap come loose and actually fall in the bladder and leak air. May have been an isolated case but still super glueing the rubber peice in place was kinda ghetto by my standards.
If you dont have oil all over it, one of the major reasons why it would fall out down into the shock in the bladder is from a dull needle.
Post a reply to: 2017 kx250f shock nitrogen refill.
