San Antonio, TX
2017 ktm 50 sx sputtering on the top end. Carb has been cleaned more than once, reeds inspected, new CDI/stator. That didn’t help so then I replaced the top end on it and still am having the issue. Next I’m thinking of replacing the crank seals. Any ideas on the cause? Also, I’m linking a video of the bike. Thank you
https://youtu.be/w3lxi4DY1IA
Post a picture of how the connectors are bolted to the case for ground. Could be the issue.
A worn needle in carb have been known issues.
Spark plug boot.
Check this and test ride.
Sounds like powervalve stuck or not connected to diaphragm.
Pull pipe put finger in to manually move valve.
Post a reply to: 2017 ktm 50 sx sputtering top end
