The manual says minimum air pressure recommended is 102psi, I tried this today and my fork height dropped about 2-3 inches. Has anyone else tried it at this pressure? I am wondering if this could be good for flat track racing...
I have no real world experience with air forks, but you should be careful doing that. It may have sacked out because of a air chamber leak. Do they extend back to normal length if you pump them back up to 140?
Edited Date/Time:
I think you read it wrong, it is a base setting of 10.2 Bar which is equal to 148 PSI.
Oops, I read your post wrong and see you tried the minimum haha. I'm not flat tracker but I think a stiffer setup with shortened forks might work nicer.
It seems that with that low a pressure and that much fork compression, you will be in the wrong part of the fork stroke to have good dampening.
