Fontana, CA
1/4/2020 8:46am
Bought new but old stock and bike has only 36 hrs and had top end at 27. This problem occurred out of the blue mid race. Bike starts and runs perfect up to where it refuses to rev out. I cleaned out the carb best i could at the track but same. Had carb apart on the bench and was spotless but blew everything clean with an airline anyway. Same. Read about sliencer issues but it's clear with no rattles and I even pushed a hose through it without problems. P/V works if I move the arm not sure if there are other issues to check with it. Readng about stator problems there always seem to be popping, missing, type issues but up to the point it stops revving it runs spot on. I might be able to borrow a donor bike to swap parts but want the least risk to messing up another bike. CDI will be simplest to switch followed by coil and stator is bottom of my want to switch list. Anything else it could be. Thx for reading.
Check the reeds.
I'd try swapping the complete carb from the other bike so you can at least rule out or narrow it down to the carb.
Then try swapping the complete tank and cap from the other bike. Might be a clogged petcock screen or gas cap vent.
There is a pin in the power valve governor mechanism that can break and that will prevent the power valve from opening. This would coincide with the sudden onset you experienced. You can check the PV operation by removing the pipe and then the right cylinder cover. Reinstall the pipe and rev the bike on the stand to observe full travel.
While you have the pipe off, inspect the inside of the pipe and silencer core for excessive carbon buildup. Especially if you run any kind of castor oil.
I thought it was possible that his issue had something to do with the CDI unit and the 2011 change where they added the shift position sensor.
In 2011 the USA model of the YZ250 got the shift position sensor and a different CDI unit as well as that massive silencer. My understanding is that feature changes the ignition timing when the bike is in neutral. It's just a clever way for the bike to meet more strict global sound regulations.
His problem was intermittent, it would run like that at start-up and be stuck in that state for a bit. If he shut the bike off and started it back up it would still be in that weird state. Randomly it would go back to running normally.
We tried my 2010 and 2002 CDI units on his bike when it was running that way and it ran perfectly with the older ECUs. If you have a donor bike, try swapping CDI modules between them.
Update. Got the donor bike so ran that up with the cover off and it seems you don't need to rev it that much for the arm to move. Need to dismantle the whole thing and check what's happened. The pin, as suggested, looks like a prime suspect.
Made a mess of this bolt but I think the thread it goes into is reclaimable with a tap to clean it up.
I take it loctite isn't a cure then? Maybe I will use the red stuff and heat it to remove when I have to.
Compare to Socal and add £3 shipping
Part Stock Qty Price
YZ250 – CLUTCH
BOLT, FLANGE
90105-10445
BACKORDER
NO STOCK
1 ×
£7.76 £7.76
Less than $4 stateside.
Part number 5: BOLT, WASHER BASED 90105-10445-00 $4.55
https://www.bikebandit.com/oem-parts/2017-yamaha-yz250-yz250h2/o/m15918…
This same thing happened to me just a week ago now my governor gear doesnt fit on the crank
Post a reply to: 2017 YZ250 no top end rev
