2017 Kxf450 oil leak
1/1/2019 6:46 AM
Have an oil leak on the left side of the engine, around the front sprocket area, taking a guess it might me the seal behind the front sprocket, anyone had to replace this and if so is it a big job? Like having to split the cases etc?
Thanks
1/1/2019 7:00 AM
Pop your front sprocket off. Use a hook to pull the seal. Tap the new seal in. Done.
Super easy fix.
1/1/2019 7:31 AM
There is also a collar behind the front sprocket that has an o-ring behind it. As stated above it could be the seal, but it could also be this o-ring.
1/1/2019 7:42 AM
The collar can also have a grove worn in it.
1/1/2019 7:58 AM
Ok thanks guys will look into it, another thing just started happening which is the launch control light keeps coming on in 1as/2nd gear without me touching it, I've unplugged it from the loomb/harness, cleaned connections but still doing it, stops flashing when I get to third
Thanks
1/2/2019 12:05 PM
Got the sprocket and seat off, but seems like the spacer is interference fitted and can't get it off the shaft, have pulled it and leveraged it as much as I feel comfortable without breaking anything, does the spacer 100% come off because it doesn't want to budge, heated it up and everything
1/2/2019 2:19 PM
pictures would be nice.
1/2/2019 5:38 PM
Edited Date/Time: 1/2/2019 5:39 PM
Yes the collar comes off. It has an oring in it.
