Washington, PA
6/30/2020 8:59am
Bike would start and run fine but would just shut down. It would start right back up but then shut off. Rode it the other day for ten minutes and shut off but won’t start now. Changed small tube filter. Pump seems to be kicking on and pressuring the lines up. Whenever I break tbat connection it sprays gas out. Anybody have any idea if it could be the pump or the filter in the tank? Fi light lights up when trying to start then shuts off.
Diagnose.
Slavens racing also sells a fuel pressure gauge that you can check your fuel pressure with on that bike it should be 48 to 52 psi approximately if the fuel pump is good! If you have low fuel pressure the fuel
Pump is starting to go out.
And if you remove the valve cover you’ll be able to inspect the top end, to make sure it’s getting oil and doesn’t look burnt
Post a reply to: 2017 Kim 350sxf fuel issue
