2017 KTM SXF350 HELP!!!!!
mikejones202
Wrightsville, PA US
3189th
Here's what happened:
The bike has 43 hours on it. A few months ago the bike would not start and turned out the connector for the electric start button got water in it and the connector corroded. Replaced the starter relay and wired the main wiring harness directly to the starter button. Problem solved.
This past week while riding, the bike just randomly shut off in a corner and would not restart. We tried a new battery and it started, then put it in gear and it just shut off again and would not start back up. You can hear the fuel pump turn on, but nothing after that. I am not sure where to even start.
Someone told me it could be the fuel filter that is clogged, so I will start with that tonight.
Any other suggestions? Not very strong when it comes to electrical
kb228
Mansfield, OH US
12/28/2018 10:08am
Does it start when its in neutral and then dies in gear - every time? Or does the starter not even turn over?
Paul_Pitzonka
Grand Terrace, CA US
12/28/2018 10:18am
first I would check to make sure you’re getting a nice strong spark... if you are then I would lead towards checking the fuel delivery system.. possibly a clogged filter, also may be a weak fuel pump or plugged/ dirty injector... my bet is on the pump I have seen several KTMs with no start issue caused by a weak pump... check inline pressure that will give you a good indication of the condition of the fuel system... if the pressure checks correctly check the injector spray pattern have also seen the o-rings on the fuel rail deteriorate and plug injectors...
Paul_Pitzonka
12/28/2018 10:31am
This is a good question does it still turn over? If not disregard my advice your problem is else where...
mikejones202
Wrightsville, PA US
3189th
12/28/2018 11:42am
It did the last time it started, now it wont even turn over. You just hear the starter relay clicking and thats it. Wont fire up.
kb228
Mansfield, OH US
12/28/2018 1:14pm
Try another battery
mikejones202
Wrightsville, PA US
3189th
12/28/2018 1:44pm
kb228 wrote:
Try another battery
That is the plan. Thanks for the help so far. Will update later.
mikejones202
Wrightsville, PA US
3189th
12/29/2018 9:19am
Tried a new battery and replaced the in line fuel filter. Noticed fuel pump did not turn on when warming up the battery, she started but as soon as you give it gas it shuts off. Trying a different tank today from a buddies bike and I think it may be the fuel pump that is shot. Any suggestions?
MX915
Central, NJ US
12/29/2018 9:51am
If the pump isnt turning on try replacing the small relay in the airbox, not the larger starter relay.
mikejones202
Wrightsville, PA US
3189th
12/29/2018 11:04am
Swapped tanks and bike starts and runs fine. Ordering a new fuel pump today
aees
12/29/2018 2:24pm Edited Date/Time 12/29/2018 2:25pm
Hold it, there is a big chance it is not the actual fuel pump, but one of the tubes of the fuel filter in the tank that is leaking (so it loses pressure when you hit the throttle). Quiet much cheaper to replace those with 3rd part then the complete fuel pump package.
Cody427
Xenia, OH US
1/3/2019 9:47am
May sound stupid. But check the 10 amp fuses that are under the seat next to the battery. Mine wouldn't start after something similar and what do you know it was a fuse. Wish I would've checked before panic set in.
Braaaphole
Spring, TX US
1/3/2019 4:39pm
Pull the fuel pump out and ensure the fuel line isn't kinked. This is a known problem.
If you do have to change the pump, search around and you can find the individual pump for a fraction of the price of the entire assembly.
ktm-5
Ravenna, MI US
1/4/2019 9:55am
I had a kink in my 16 250f which I believe is the root cause of why the pumps take a shit. B4 mine died I replaced both inside fuel lines, eliminated inside filter and little outside filter with an external filter. Zero problems so far and only cost me about $70 to fix
Post a reply to: 2017 KTM SXF350 HELP!!!!!
