2017 KTM 450sxf starting issues
Cole685
Union, MI US
I have a 2017 KTM 450sx-f that will not start. Towards the end of the season this year it was getting harder to start, but it would still start eventually and would at least fire. I figured I’d change the spark plug and now it won’t start at all. It has spark, it turns over, and it has an occasional backfire, however aside from the occasional backfire the bikes not even trying to start. I’ve tried everything I can think of so I’m open to any suggestions and would greatly appreciate any help.
CarlinoJoeVideo
Portland/Los Angeles, CA US
2361st
2/23/2021 8:00pm
New gAs, adjust valves, clean injector, new plug, charge battery, EcU remap from Twisted.
AE448
2/25/2021 3:56am Edited Date/Time 2/25/2021 3:58am
Seeing as you've changed the plug, I would clean the injectors and check your valves haven't tightened up. Also as Carlino said above, make sure your battery is charged. Seeing as you have spark I think the culprit is likely to be one of these things.
JK714
Durham, NC US
3/3/2021 1:33pm
The Motion Pro injector cleaner works great. Well worth the money.
Post a reply to: 2017 KTM 450sxf starting issues
