2017 KTM 450 SXF Clutch Slave
2/27/2019 8:01 AM
I am replacing my Clutch Slave with an OEM unit, and there appears to be a C-clip or collar around the top plunger/diaphragm. Should I remove this or leave this in? I'm not sure if it was there for shipping etc?
Thanks in advance!
Mike
2/27/2019 3:24 PM
Can you post photo?
2/27/2019 5:23 PM
Edited Date/Time: 2/27/2019 5:23 PM
According to the diagram, you have a piston, o ring, return spring that go into the slave cylinder. Obviously you will have the two cooper washers and banjo bolt for the hose and a gasket bolting the cylinder to the case.
2/28/2019 7:10 AM
Thanks, I will try and post a pic of the clutch slave.
For a bit more clarification, there is a C-Clip that is holding or preventing the Piston from moving too far forward. The piston cannot come out with it in. I removed it thinking it was to keep the part(s) together for shipping purposes.
3/10/2019 2:17 PM
CarlinoJoeVideo wrote:
Can you post photo?
Is the C-clip suppose stay in the Slave?
3/10/2019 6:34 PM
that clip stays in, the only part removed to install on the bike is that little clear plastic piece in where the banjo bolt goes.
