Phoenix, AZ
6/3/2020 7:09pm
Vital i need your help.
I rebuilt the top end in my bike. Pretty standard deal. But after assembling everything the bike would only start with the "choke" lever pulled out.
And once started its just pops on idle and pops when i give any throttle.
So far I have.
-Changed exhaust back to stock
-Checked timing
-Cleaned fuel injector using a 12v battery method
-Checked electrical connectors I disconnected and cleaned them
Any other suggestions would be great! Or a general direction I should be pointed in thank you
Edit: I forgot to mention the fi light flashes continually. Non stop blinking no pattern.
So far I have.
-Checked timing
Did you check for exhaust leaks or a lean tps setting?
I would get another set of unbiased eyes to look at the cam timing again
When though and tried a new ecu and cam. Same problem. Also re tore down the top end checked the valves to be sure none where chipped or burnt. It was a very consistent pop which had be thinking it was a sensor of some sort.
So I started disconnecting the map sensor and so forth. Disconnected the starter relay and the bike ran perfect. So I'm guessing I have a short wire somewhere in my starter circuit.
For now I don't have a starter working but at least the bike runs!
Glad you found the issue.
Post a reply to: 2017 Crf won't stop popping
