- Pick trends
- Create a private league
- And more!
This was my 2018 KTM 150SX new off the floor, last lasted .9 of an hour.
Back in the good old days, starting a 500 smoker was a right of passage. Lol. If that thing backfired and popped over backward once, it would break your leg. You learned to quickly bring the kick lever all the way back up asap to prevent this.
Best of luck with the new bike in the spring!
@seth505 yea that’s what holds the idle gear
Disgusting that Husqvarna would not do a thing the bike had only done 70hrs!!! we were told its not a common problem it clearly is and they want to f...kin ignore it.i will never buy another KTM/Husky in my life nor will the team.
You can clearly see this is a weak point as to the hideous webbed support on the casting.
Does the bronze bushing spin on the ID also or just the OD between itself and the ID of the idler gear?
Because I was thinking to stick the bronze idler gear bushing on with loc-tite 660.
So any ideas if the brass idler bushing spins on the post too or just the inside diameter of the idler gear?
It took up the gap between the Aluminum post boss and the ID of the brass idler bushing. I maybe put 20 more hours on the bike with no issues before sending it down the line with a work of caution to the new owner. He's either had no further problems or hasn't mentioned them to me (as he lives around the corner).
Had idler gear boss failure few weeks ago in 2017 TC250 even with long bolt mod at 145hours in the bike. Bike was originally raced and long bolt mod was done at about 60hours. I have been always kicking gently and this happened when finding the compression.
Cost was ~1500€ with new cases, engine seal kit, idler gear, conrod and work related to conrod change ... Had a new piston already in shelf.
Was thinking to part the bike but decided to rebuild...
That sucks, I will admit KTM paid to fix mine in full, including labor. I had about 80 hours when mine went out.
Will the 18 case bolt up???
i have no idea what to do
Yes, you can use 2018 cases. Other cases from newer models might also work.
Has anyone repaired 2017 idler gear mount with welding and machining?
I did put broken ones to my "trophy wall" but have been wondering If I should try to make a fix someday
I saw a JB weld repair:
https://www.ktmtalk.com/threads/new-17-250-300-kicker-update.532535/#po…
Post a reply to: 2017 250SX idle gear case break?
