Hi i recently bought a 2016 sxf 250, it runs perfect but everytime i ride it it seems to use water, the water level drops about half an inch everytime and drops just below the radiator fins inside. Is this normal or is there a problem? I cant see any leaks anywere either. Any help would be good
1. Weak radiator cap. Replace with a new one.
2. Water pump seals are bad. The water would come out a hole under the case while running. This will require that the water pump be rebuilt with new seals bearing and maybe a new shaft.
I run the coolant just over the fins.
Check the radiators aren’t leaking anywhere.
Drain the oil and make sure it’s not getting inside the engine anywhere.
Post a reply to: 2016 sxf 250
