So I’m having an issue getting my bike to start but once it’s running not a single issue. Sometimes if I give it a little throttle that helps. The choke in warm weather helps as well. So I replaced my battery as well as the fuel pump relay because they were both bad. My fuel pump is dumping out fuel but I’m not sure the PSI. I’m leaning towards a possible bad TPS or clogged injector? Thanks!
