Houston, TX
Has anyone else seen or had this issue of oil leaking from this plug? It's the plug that is not required to be removed for oil changes, and behind it is a spring and ball which regulate oil pressure. When I first noticed the leak the plug had some dirt built up around it. I cleaned the plug and replaced the washer. It continued to leak so I replaced the plug and the washer. A new plug and washer didn't fix the leak, so I took the bike back to Munn Racing this weekend. Munn Racing took it apart and inspected it and found no cracks or damage to the plug or the case halve and sanded the washer flat. Upon reassembly by the dealership it is still leaking. I am lost here, no damage to the case, new plug, new washers and still leaking oil.
Post a reply to: 2016 450sxf leaking oil
