2015 RM-Z 250 Electrical Issue
2/11/2018 10:07 AM
Bike freshly assembled.
Theres no power to the ignition or injector.
There is power to the fuel pump.
Any ideas why this could be?
2016 YZ250F
2007 CR125R
2/11/2018 5:40 PM
Double check all your electrical connection for dirt, rust or bad connections.
2/12/2018 7:14 AM
Thanks for the response.
We went through all the connections. We found no corrosion or broken pins. The ground was also good.
Is there a chance the ecu went bad? It was all fine before it was taken apart.
2016 YZ250F
2007 CR125R
2/12/2018 8:44 AM
I would check the stator before considering the ecu as bad.
2/12/2018 8:55 AM
Did you powdercoat the frame? I've seen some grounding issues with powdercoat. I know most don't coat aluminum frames, but I have seen people do it.
2/12/2018 11:54 AM
No powdercoating. we checked the ground and it was good.
2016 YZ250F
2007 CR125R
2/12/2018 11:56 AM
I did resistance checks on it and it came back good. but from what I understand the only real way to check would be to find a known working stator and switch it out?
2016 YZ250F
2007 CR125R
2/13/2018 6:49 PM
Did you say fresh assembly? There are a couple two and three pin connectors that are able to get connected wrong.
Black plastic to black. Grey to grey. White to white. Look for a grey to black by accident. It happens.
