2014 ktm 50sx no start
8/7/2021 8:59 AM
Working on a 2014 ktm 50sx with no start issue. Has spark but looks never narrow and white. Replaced flywheel rotor, stator, spark plug, boot, wire, and coil. Tried unplugging kill switch. Still no start, still weak looking spark. Maybe spark like that is normal on these? Have even tried a shot of starting fluid and not even a sputter. Any ideas?
8/7/2021 2:46 PM
Have you done a compression test?
Have you done an OHMS test of the coil?
Have you done a leak test?
8/7/2021 7:26 PM
Did compression test and was good. Ohmed out old stator and was weak. New one tested good. Did not do a leak test. I did pull reeds and they did not look like they were sealing well. I tried to flip reeds but still could not get a good seal. Could that be the issue?
