2014 KTM hydraulic clutch issue
9/17/2018 7:21 PM
Edited Date/Time: 9/17/2018 7:29 PM
Engine will die if you hold the clutch in with the transmission in gear after about 45 seconds. It's like it tries to engage. No leaks that I can see and the reservoir does not get low on fluid. I have bled led the system but it doesn't seem to help.
9/17/2018 8:14 PM
Id do new clutch plates, fibers and steel.
Also, its not the best to hold the clutch in for that long in gear, prob burning your plates up.
9/18/2018 2:25 AM
Yeah, joe is right
Holding the clutch in for ages with it in gear, there will always be a little bit of drag that will create heat and swell the plates and cause it to stall.
9/18/2018 1:22 PM
Bruce372 wrote:
Yeah, joe is right
Holding the clutch in for ages with it in gear, there will always be a little bit of drag that will create ...more
Thanks, yeah I've been wondering about that. Just bought it used and inherited this issue.
