- Pick trends
- Create a private league
- And more!
The carbon could just be bad fuel or if it’s oil, I’ve had valve guide seals wear. But that was on a 250SXF.
Are you going to replace the crank?
O do suggest you checking the cylinder as I seem to see a ring wear ridge at the top of the cylinder and if so, it could cause issues when new rings are installed if it is no addressed.
After posting this, I did what everyone fears when they are putting a new piston in... I dropped the piston pin C-clip into the crankcase! I had the crank stuffed with paper towels and it managed to get by. I had to fish around with my magnetic tip pickup tool for over 20 minutes before I got it out. This tool is worth its weight in gold!
Post a reply to: 2014 KTM 450 sxf piston 150 hours
