2013 rmz250 runs rough
4/12/2018 12:11 PM
Hey so i have been having a lingering issue with my 2013 rmz250.
upon start up, it runs rough to where i cant touch the throttle without it dying. after it settles it runs ok but is a little poppy.
I had the grey(rich) coupler installed and changed to the white(lean) with no difference noticed. I also had a power commander fuel mapping that i pulled that made no change.
Also I have the hot start cable unmounted from the bars and coiled up along the frame but the cable is loose, not being pulled on.
Could this be a sensor or injector?
"If you feel in control, you're not going fast enough" ~Mario Andretti
4/12/2018 1:30 PM
upon start up, it runs rough to where i cant touch the ...more
I removed my hot start,, team suzuki trick. Run good fuel, full fmf 4.1, remapped ecu, moto tassinari air boot, 2 stroke cage. 13 rmz 450, bike geared 13-51. Bike rips.
4/12/2018 2:57 PM
Dirty fuel injector......
TPS setting incorrect......
