Lincoln, CA
Scenario's...
When bike sits for more than a couple of weeks, it's a 50/50 whether it will start. When it does start from being cold and sitting, it will fire off in a couple of kicks. If it doesn't fire in a couple kicks, then it won't start, and slight smell of gas. Then when I bump start it, it fires off immediately. Then the rest of the day it start's first kick, runs like a champ.
If I start it every few day's, there's no issues. This would be the easy fix I guess, just not always around.
The 50/50 ratio whether it start's or not is very frustrating, cause then I don't even know if I'm taking it out.
Always run VPR, or T-4 race gas. Has Vortex ignition, FMF pipe, ported head, and a fly wheel weight.
Capacitor, fuel injector, Vortex setting (rich maybe) what's your thoughts?
Thanks for any help!
Thanks!
I'm fairly anal with maintenance
I will say, if I give it a "bitch kick" it has a much better chance of starting than if I give it the hard abrupt CR500 kick.
I use this.
http://www.split-stream.com/products/splitstream-fuel-filter-honda-crf-…
These intermittent problems are never easy to chase down.
Guess it's time I start using my 17 as my primary bike, and start going through the 13
Thanks everyone for your input. I'll keep you posted with what I find.
Thanks!
May I suggest a fuel sock for your fuel tank. You may want to pull the fuel pump and filter and take a look at it.
Post a reply to: 2013 Honda 450 starting issues
