Ijamsville, MD
My bike will not start I’ve just checked and shimmed the valves, replaced my kill switch because that is a known problem on these bikes when they will not start, checked the spark and fuel pump and am getting both spark and fuel now. I have gone through every connector and everything I have tried I can not get the bike to start. Please help!!
Valves leaking, poor compression, poor fuel flow, weak spark ( any color other than bright blue) or timing issues would be things to recheck.
You say the valves were reshimmed....How many times has this been done? How much change was there?
Last thing i can think of is old valves and seats or a worn piston/rings.
Does the auto decomp work? Its not stuck and leaving an exhaust valve open?
You can have several different colors in a spark and it will still not fire the plug.
How do you know if the injector is clean? Clean it.
Post a reply to: 2012 crf250r won’t start
