North Haven, CT
ok so i completely rebuilt my engine over the winter. stroker crank hot cams stage one cam wiesco hi comp piston. ported and polished the head and every new electrical component on the bike. i also put a yoshimuria RS-4D full exhaust system on.and i run vp110 for fuel. my problem is when i set the tps to .5 volts like honda requires it will either die when i touch the throttle or back fire obnoxiously on decel. i get the bike running fine with the tps set at 1.08volts which sounds crazy. it was a little hard to start when hot if i stalled it or went down. i played with the tps and went up to 1.13 volts and it was a lot better. this past friday i had an mx race so i went through the bike lubing everything and so on and went to adjust my valves. they were way out on the loose side for some reason so i shimmed them up and put them into spec. went out for practice friday and the bike flamed out in the corner instantly and could not get it started. brought it back to the pits got it started and adjusted the tps back down to 1.08volts. the bike ran good until i went down because i was riding over my head trying to catch the leader (dumbass). couldn't get the bike started again until it cooled down. i have a GET power ecu in it but none of the remaps do anything for fuel adjustment. almost thinking about loosening up the valves again. any advice? should i send my stock ecu to Tokyo Mods and have it mapped? I'm past being frustrated with this bike. since the day i bought it it has always had a hard starting problem when it's hot. Someone please help. seriously thinking about going back to a carbuerated bike.
2. Ultri sonic clean your injector. It may be leaking when closed and thus excess fuel is there when starting.
3. Reduce your fuel octane. Your octane is just too high and causes a slow and incomplete fuel burn.
You may also want to look for an air leak in the intake system which would confuse the results of any TPS setting.
A leaking injector will also cause these issues.
Post a reply to: 2011 crf450r problems. at a complete loss
