4/18/2021 6:03am
I have purchased this bike recently. Most recently the bike had been running well during a outing. The bike was brought home. The next time out the bike wouldn't start. The bike was brought in and the complete fuel pump assembly was replaced and a clutch cable. The bike was serviced at the same time. Brought it home and started the bike. The bike ran until warm then shit off the high idle button. The bike dies immediately! I pull the high idle and the bike takes a kick maybe 2 and starts right up. If I leave the high idle pulled the bike continues to run. If I twist the throttle fast it dies immediately. If I do the same rest again but twist the throttle slowly just a little I can then crack it open and it has no hesitation what so ever! I tested the throttle position sensor and adjusted it slightly. This has not made any difference in the way it runs. Any suggestions as to what to test next without just blindly ordering parts?
Thanks,
Thanks,
I will try some adjustments and let you all know how it turns out.
It seems that the previous owner had this bike serviced at the same time the fuel pump assembly was replaced! This is only a guess, but I believe only 1 drain plug was pulled and the full 1.2 liters or more was added! I dropped what looked like almost 1.5 times as much as the recommended amount. I read on another post of this happening to someone else. I had started it a few times and still didn't seem to be working! The post I read also said it took him to run a tank of fuel through before it started running the way it should. Later I had a friend stop by so I was going through the motions to show him what it was doing. After I had it warm I showed him how it sounded if I tried to crack the throttle and how it wanted to stall but if I slowly opened the throttle I could crack it all I wanted and it would work fine! After doing this I got off the bike and let it idle. To my surprise It stayed running and sounded amazing! I let the bike just idle there for 10 or 15 minutes no problem, even if I cracked the throttle from the relaxed state no problem! I am ecstatic! Was it the oil or was it something else? I don't know for sure but I can tell you it is running very well and very different than it has up till now! Thanks again for the help provided! Keep the rubber to the ground and we'll see you out on the trails!
Post a reply to: 2010 yz450f won't idle without high *FIGURED OUT*
