6/28/2019 5:40am
Hey guys! Hoping to have someone with some more mechanical knowledge and skill point me in the correct direction here. I have torn down a friends 2009 KX250F and done a top end rebuild. New valves are installed and the cylinder head cleaned up, and in the process of torquing down the camshaft cap and cams to check valve clearances I have noticed the intake cam is more or less seized. With a fair amount of force it will move but certainly not freely as it should. The kids original complaint was that the bike seized in spring of last year while riding, and a few months later it was magically un-seized. I suppose a damaged cam/journal could explain why he may believe it was seized when that was not the case. I’ve torn the motor down and replaced the piston and inspected the crank and all is in working order. Again, upon re-assembly I was near the stage of checking valve clearances and have now noticed the intake cam is not seated correctly as it does not move freely at all. The bearing seems to be okay on the cam itself and rotates smoothly. My main question would be is it the camshaft that would be damaged or the cam journal on the cylinder head? If it’s the cylinder head it’s a kick in the ass after completely cleaning and installing new valves and springs but I’ll live. And if it is an issue with the cam journal being burnt up, it’s likely starving for oil? Does anyone have any info or insight If this was similar with kx’s of these years? Just appreciate any insight anyone may have. Hoping to have this reconciled and the kid riding soon!
The head on my 2009 had a destroyed cam journal when i bought it. From what i could see it was from not tightening the cap bolts correctly and in order. no signs of oil starvation from a clogged filter or anything.
Post a reply to: 2009 KX250F Intake Cam and Journals
