Here’s the problem: My 2008 rmz250 hits what seems to be false neutral when shifting from 3rd to 4th gear. I did split the cases and inspect the gears/forks/dogs and couldn’t seem to find anything that stuck out as to why this bike won’t shift correctly. Also, to back that up, when the bike is not running it will shift through all of the gears fine, locking the shaft so that I know it is going into gear. I was thinking maybe the star cam is worn or the detent spring is just weak and isn’t holding it in gear. Does anyone have any idea what might be causing this?
