NE Iowa, IA
What is the correct aftermarket (Pro-X, Vertex) piston size to run? I believe the "A" cylinder would run a 66.34mm, but not sure on the "B".
B Piston OD: 66.333 - 66.340 mm (2.6115 - 2.6118 in)
The A pistons are larger than the B pistons per Honda's sizing system.
Vertex has different sizes
A 66.34
B 66.35
C 66.36
D 66.37
And in the past you had E and F.
Once you put a D in a A size cylinder then there is no turning back.
Great piston a vertex, run it for 15 hours then it's done. 14 years now running the same size piston in the still original cylinder, a size B vertex. Prox for a honda is a shit piston ,same as a honda piston.
Post a reply to: 2007 CR250 new "B" cylinder , piston size
