Orange City, IA
Have a 2006 crf250. Bought not running with no spark. Replaced cdi, stator, coil, spark plug. Continuity tested all wiring and all checked out. Checked, rechecked, and triple checked timing. All good. Tried disconnecting kill switch, still nothing. Checked all grounds. Any ideas? I’ve gone from zero spark, to now I have spark but only at the end of the kick stroke. Will start if I pull it behind something and bump start but will only run at mid-upper rpms.
PawPAW
Woodruff key may have broken and cause flywheel to move.
Without knowing the history I would check those valves out immediately...
Post a reply to: 2006 crf250r repair ideas needed!
