2006 crf250r no start. Any ideas?
5/12/2021 11:40 AM
Working on a 2006 CRF250R that needed valves shimmed. Shimmed intake and exhaust to spec in manual and timed and wouldn't even get a pop. Checked spark and had very random spark. Rechecked timing and was good. Checked ohm readings on stator and was found odd numbers compared to manual. Replaced stator and now I have consistent spark every kick. Still am not getting even a pop or sputter. Tried feeding starting fluid straight into the carb with no luck. Any ideas for me to try next?
5/12/2021 12:41 PM
I’d start with a leak down and go from there, just because the valves are in spec doesn’t mean they’re sealing all the way. Those bikes are notorious for eating valves.
5/12/2021 12:45 PM
paddyB745 wrote:
I’d start with a leak down and go from there, just because the valves are in spec doesn’t mean they’re sealing all the way. ...more
Will do. Actually just bought a leak down tester so I will put it on its maiden voyage and report back. Thanks
