2006 crf 250 isn’t engaging into gear Help please!
7/5/2018 5:55 AM
So I split the cases on the bike and installed a new crank and put the transmission back in. All the component stuff on the transmission are moving with the drum when I spin it and clicking through. I put the case half back on and assembled the shifter drum. Well when I go to turn it with the socket it won’t engage into gear. I noticed I did not have the little dowel/roller that the drum sits on. Is this my problem? I want to make sure it is before I put everything back together and then have to tear it apart to split everything again because it’s something to do with the transmission. It’s like it will turn a half turn but wont turn to the next gear.
7/5/2018 7:41 AM
Personally id start by making sure you have all the parts
7/5/2018 9:31 AM
That’s what I’m gonna do I guess. This thing has been a pain in the butt so far And I’m tired of dealing with it to be honest so I’m trying not to split the cases and if something is wrong with the transmission inside then I am clueless
