2006 RM 125 Spark Plug Heat Level #7 vs #8
1/29/2021 9:28 PM
Hi all,
My dealer sold me the R6918B-7 spark plug and the manual calls for a R6918B-8 plug. Hence, the plug the dealer sold me will run hotter. What damage or danger am I risking by using this spark plug? I don't want to melt the spark plug and do damage to the engine. My gut tells me to only use #8 rated plugs. However, if I use race fuel (I currently do), which runs cooler, or run a leaner mix (more oil; run 32:1 instead of 40:1) will that counter the extra heat? Or just be safe and return it for a #8 plug?
Thoughts?
1/30/2021 7:20 AM
Those suzukis are sensitive to plug type, and that design is to stop the ground strap falling off and ruining the engine.
With race gas and rhe special 7 plug, you might be ok....
But $30 for rhe right plug is cheaper than the repairs
1/30/2021 7:51 AM
I would only run the 8
1/30/2021 9:57 PM
FYI, a leaner mix runs hotter. You are correct that more oil = leaner fuel/air mixture, however.
I'd run the #8 plug.
Braaapin' aint easy.
2/1/2021 11:25 AM
What type of riding, and what’s your skill level?
Your answer could indicate a 7, 8, or 9
2/1/2021 10:48 PM
Desert riding. Fairly fast A rider. I stay in the upper rpms in the 125.
2/2/2021 9:08 AM
Definitely go with the colder plug. (#8.)
2/3/2021 6:02 PM
That 7 would surely melt a hole in your piston!
They do make a 9, if anyone would run a 9 you absolutely qualify.
