Goldsboro, NC
12/10/2018 10:27am
Hi guys,
I have a 2006 CR125 that is constantly fouling plugs. I'm using the BR8 (the hotter plug.) I live in North Carolina so we are at sea level. I moved from New Mexico ay 6,000 and she ran like a champ. Never had a problem with fouling plugs. I did a top end rebuild before I moved; piston, cylinder, and cylinder head and she ran great. Then I moved to sea level and always fouls plugs. I'm using a 410 main, 37.5 pilot (I did change the jets when I moved and the main and pilot are BRAND NEW genuine Honda parts so they're not clogged), and the second need clip position 32:1 ratio with amsoil dominator oil and 93 non-ethanol. I can ride it for about 20 minutes and it pulls hard and feels amazing. Then 5 minutes of putting around she shuts off. Every time the plug is wet and black. I started getting some oil shooting out the exhaust so I changed the right crank seal, stopped the oil problem. BUT it still is having the same plug fouling issue. My next plan of action was to do a resistance test of the stator. If you guys have any other ideas or checks please feel free to comment. I've also cleaned the carb and replaced the reeds with boyessen reeds. Not sure what else to do before looking into the electrical system. Thanks!
carb
if it barely leaks the extra fuel heads towards the cylinder instead of out the overflow and it will be slightly rich
Those jet sizes should be close to what you need. Do a plug test right after your 20 minute Moto and see if your burning a lite chocolate color. Also check your float height. What needle are you using? See if you can find the number on it.
I've been checking the plug every time it foulds and is straight black and wet. i'll find the picture and post it.
I'm not sure on the needle, I havent changed it, only the position. I'm in the middle east right now so i wont be able to check the needle until next month
Simpel, go lower on the main.if the main is right then you can play with the rest. There is moreee then enuff oil on the spark thats for sure. So mixing to much oil or you ride it not hard enuff. Or try 40:1 or try a different oil
A 85 and a 125 will foul plugs right away if the jetting is to rich and you don't burn it but cruising with the bike.
One of the issues with the stock jetting is the taper of the needle. The JD kit supplies two replacement needles and overall jetting specs (and jets) covering a range of conditions/altitudes. The kit absolutely cleaned up my son's bike. It was so rich when we bought it that the original owner had installed a super hot lawn mower plug to get it to run. (Glad we discovered that right away).
Good luck.
https://www.procircuit.com/jettingspecs2.htm#2006
MXA suggests 440, a 27-67 needle in position 3 and a 50 pilot.
https://motocrossactionmag.com/2006-honda-cr125-test/
Stock is a 430 with a 55 pilot. Honda's jetting from the factory may be rich, but not that rich.
If you're running a 37.5 pilot and fouling plugs, there's a mechanical issue. Start with the right side crank seal.
Post a reply to: 2006 CR125 fouling plugs constantly
