Simi Valley, CA
Went riding Sunday and after 10-15 minutes my bike would bog down and eventually die. After 5 minutes it would fire back and run perfectly normal. The last time I rode this bike was the end of October, it did the same thing. So I took the bowl off and replaced jet and cleaned the bowl, dumped the gas. The problem is intermittent. Does this sound like the stator?
Also check the OHMs readings on the ignition coil, both primary and secondary sides.
Post a reply to: 2005 KX 250
