Elizabethtown, KY
2405th
I have a 2004 rm250 I just did a rebuild on with new crank and piston. It has not ran right since we had it. Was thinking it needed a rebuild. I am having problem with low to mid throttle. It is acting like it is running really rich but I have went all the way down to a 38 pilot in it. It just blubbers until I give it a little more and it will clean out. But still sometimes when it cleans out on top it will kinda act like it’s cutting out. Have checked power valve, float in carb, unplugged the kill switch, the ground on the coil, all vent lines, played with lots of different jetting and air screw settings, advanced and retarded the timing. I am leaning towards maybe a bad cdi box or stator? Any ideas?
Post a reply to: 2004 rm250 help
