2004 CR125 with a different year motor
4/8/2018 6:50 PM
Hey guys, I am currently building an 04 CR125 but am trying to get rid of that shitty cable power valve on it by going to a different year motor. From the research I have gathered so far, it looks like the cases from atleast 03 are the same pattern and will work. 05 and up, I am not sure... Also, with regards to the wiring harness, cdi, and all the electrical, I am sure ill have to take the wiring harness from whatever year motor I use.
If anyone has done a different year motor in an 04 frame, any help would be greatly appreciated!
4/8/2018 7:15 PM
Any help is appreciated!
much ty. How to spot a paid forum poster/artificial forum traffic producer (see list of actions/phrases below):
Copius pattern amounts of phrases like “Anyone have”..., “Anybody know?”.... and their variations.
Thoughts?
Thanks in advance!
4/9/2018 3:59 PM
92-06 will bolt in. 97-older need cases drilled out for larger mounting bolts. I would get CDI & wiring harness. When I run my 93 bottom end in our 02 I just switch the electronics over............
4/9/2018 7:21 PM
Thanks boss.
4/9/2018 9:02 PM
you should finagle a ktm motor in there wink
"If you feel in control, you're not going fast enough" ~Mario Andretti
